... hondata base maps needed
... does anyone know where i can find some good base maps (beside from hondata)?... specifically, i need maps for a turbo gsr (stock gsr w/ garrett t3 and fmic)... or if any of you with similar setups would be willing to share/send me your map, i would really appreciate it... lemme know... thanks in advance...
aCe
aCe
... no, i am looking for a good base map for my setup (above) at 6psi... all the maps on the hondata site run higher boost... i need a map to a similar setup because there are no hondata tuners in colorado springs / denver (or are there?)... so if i do get the hondata i wouldnt be able to tune it til i move to florida in march/april... if you (or anyone else) can help me out, i would really appreciate it... thanks...
I also need a map for JR SC 6lb for 00 SI. I only have a 3b and need a basemap because the 3b I'm buying currently have a map for a prelude H22. If anyone can burn me one that'll be great. I'll send you a free EEPROM.
those maps are for, lets say 11psi, but boost doesnt go from 0psi to 11psi in an instant. You still have to go 1-11psi to tune your car, so you can still use the map. Just because its meant for 11psi doesnt mean you have to go 11psi, it will still work if you are only boosting 6psi.
art
art
