Will i be ok with standard injectors? b18c4 with t28 turbo low boost
Old Jul 7, 2009 | 07:48 AM
jamesfawcett's Avatar
Default Will i be ok with standard injectors? b18c4 with t28 turbo low boost
hi everyone,
i cant find the answer im looking for, everyone here seems to change their injectors when adding a turbo onto a b18 engine, is it necessary?
im only going to be running low boost, does anyone know what power the standard injectors from a b18 can run? will i be ok with about 5psi, which will maybe be arround 210bhp?
Here is a photo of my engine, i just cant afford expensive injectors at the moment,
thank you
james
Old Jul 7, 2009 | 08:05 AM
b20beast83's Avatar
Default Re: Will i be ok with standard injectors? b18c4 with t28 turbo low boost
u should at least get some dsm injectors
Old Jul 7, 2009 | 08:35 AM
turbo gsr2000's Avatar
i would get bigger one's just to be safe im runing 550injectors but i think im going to get bigger one's soon .. but be safe
Old Jul 7, 2009 | 11:46 AM
dpetro1's Avatar
you cannot run stock injectors on boost unless you use an FMU and inline fuel pump. not a good way to supply fuel to your boosted setup. honestly if you cant afford all the parts then dont boost the car yet. wait until you have more money so you can do it right and not hurt the engine
Old Jul 7, 2009 | 11:48 AM
roadsqueegy95's Avatar
as stated, get dsm injectors from a junkyard. they can be had pretty cheap.
Old Jul 7, 2009 | 11:23 PM
mephology's Avatar
Yup. I'm also on a tight budget and putting together my turbo kit. I talk to many techs and people who have boosted their cars. I was thinking of doing exactly what you did. Running low boost and to just get the turbo in then worry about the "little" parts later. Every single person said, you need to do it right or don't do it yet.
Old Jul 7, 2009 | 11:34 PM
project dc2's Avatar
do it right or dont do it yet
310's are good for bout 190-210
440's up to bout 260ish
Old Jul 8, 2009 | 04:29 AM
Turbo_TONY's Avatar
X2
Old Jul 8, 2009 | 04:41 AM
Ok everyone thanks for the input!!
I didnt realise it was so crucial, really glad i asked!
Email on its way to you now, i might as well go for the 440's im emailing you now for a price,
thank you
james
Old Jul 8, 2009 | 04:48 AM
These seem ok are these a good brand? $129
http://cgi.ebay.com/ebaymotors/DSM-4...Q5fAccessories
DSM are they a good make?
Old Jul 8, 2009 | 05:18 AM
th3pwn3r's Avatar
Haha. Yea, they're a good brand. =/
"Here are a set of 450cc injectors pulled from a perfectly running 1st gen turbo DSM"
Many people have run them without issues.
Old Jul 8, 2009 | 06:14 AM
ekb18c2's Avatar
New User
You should be fine with 5lbs of boost as long as you have an FMU and a walbro pump or something similar.
Old Jul 8, 2009 | 07:58 AM
Ive decided to buy injectors from spoolinperformance, some 440cc Lucas Factory Direct ones as his stuff has always been good,
thanks everyone for your help
james
Old Jul 8, 2009 | 08:04 AM
Axix24's Avatar
at least get some rsx type s 310 injectors
Old Jul 8, 2009 | 09:08 AM
dpetro1's Avatar
james
thats a good first step, now what eninge management do you plan on controlling those 440's with? also it would be a good time to add a walbro in-tank fuel pump
Old Jul 8, 2009 | 11:18 AM
I bought a honda Ecu with s300 and boost hardware on it:
I dont really have any experience about tuning, so im hoping to download a good base map and work it out from there.
The engines actually going in my classic mini:
Here is the honda i stripped for the engine:
Its nearly in, it will look much different when finished! It was just a 1.3 turbo before with a T3 turbo on it, so next it should be much faster with the 1.8 honda engine in there
I got my turbo manifolds from Spoolinperformance theyre beautiful!
Old Apr 11, 2010 | 05:10 AM
hey everyone,
sorry for digging up and old thread, but im working on my wiring at the moment and cant get the injectors to fit into my connectors. The little tab on the plastic plugs seems to be on the wrong side,
does anyone know if you need to mod the connectors in order to fit uprated injectors?
i bought my injectors from spoolinperformance and he said that my injectors are:
"lucas factory direct
same stuff RC and innovative sells"
please let me know if there is a mod to get them to fit so that i can get it running this is the last piece to do now
thanks
james
Old Apr 12, 2010 | 08:04 AM
Old Apr 12, 2010 | 08:08 AM
shifty35's Avatar
Snip the tab out of the injector with a pair of side cutters or a razor blade.
Old Apr 12, 2010 | 02:18 PM
EHondaJDM's Avatar
Can u just plug them right in or u need a resistor?
Old Apr 13, 2010 | 01:33 AM
Hey thats great ok ill use a dremel and cut off the small tabs,
i just recieved this reply from spoolinperformance "440's do not need resistor boxes. the ones i have are saturated." so i wont need a resistor box
thanks
james
thanks for all your help
Mephistopheles
Feb 15, 2021 05:17 PM
abusedvtec
Engine Management and Tuning
Nov 29, 2010 05:01 PM
boostcrazy1234
Apr 14, 2008 10:19 AM
TurbodTegSfaria
Nov 14, 2006 04:07 AM
jamal-188
Oct 10, 2001 12:03 PM
