D16A6-D16Y8 Swap
Old Jul 7, 2009 | 05:36 AM
WNDOPDLR's Avatar
Default D16A6-D16Y8 Swap
Noob could use some help. I am new to Hondas, but not new to cars or working on them. I recently purchased an 89 CRX SI OBD0 car with a blown engine and have found a 98 OBD2 donar car with a D16Y8 engine. Can we make this work? What do we need in addition to the engine? PCM off the donar? What about wiriing harnesses etc? My son is very goood at wiriing, but we are not real sure of what we will need from the donar car. Thanks in advance for all the thoughts and help.
Old Jul 7, 2009 | 06:28 AM
dougfunnie112's Avatar
Default Re: D16A6-D16Y8 Swap
http://www.jdmuniverse.com/forums/ho...-write-up.html
I know he isnt going from a d16a6, but it should give you some type of idea as to what is involved, parts, time, etc.
Make sure to check out the FAQ, there is some good info in there.
-Alan
Old Jul 7, 2009 | 07:56 AM
WNDOPDLR's Avatar
Great write up Thanks much.
Old Jul 7, 2009 | 08:15 AM
4drEF's Avatar
Keyboard Humorist
Nice write-up, but i'm not sure it captures what the project is.
He is looking to do a complete motor swap so I think what he needs to see is info on -
- engine mounts
- OBD-1 conversion
- Location of IAT sensor
You can use the OBD-2 injectors with a resistor box delete -or- use your stock OBD-0's with resistor box.
Stock tranny and flywheel will bolt up so no need for worry there.
Old Jul 7, 2009 | 08:43 AM
WNDOPDLR's Avatar
4drEF you are right about my project and I thank you. Having said that, it is still a great write up, took tons of time and effert, and I am apprciative to both the writer and the sender.
Old Jul 7, 2009 | 05:25 PM
- engine mounts
- OBD-1 conversion
Oh yeah wow, I kinda missed the whole part about a blown motor. Oops!
Old Jul 8, 2009 | 12:07 AM
tek44's Avatar
the motor should just drop right in, but you will have to convert it to a obd1 meaning, youll need a dizzy off an d16z6 a p28 or any other obd1 vtec ecu and run the vtec of course. good luck!!!
tek44's Avatar
oO yeha and use the d16a6 tranny unless you convert it to hydro tranny.
Old Jul 8, 2009 | 08:28 AM
4drEF's Avatar
Keyboard Humorist
For a Y8 you do NOT want the Z6 distributor.
The bolt pattern is all wrong.
Use something like the OBD-1 DX distributor and it bolts up just fine.
you can also use the OBD-2 distributor right off the Y8, but you will need to do some wiring or buy an adaptor.
Old Jul 8, 2009 | 08:40 AM
4drEF's Avatar
Keyboard Humorist
You need to use your stock driver's side mount and not the Y8 one. You will have to do a little trimming to the belt cover.
*EDIT* ^^ Double check on that mount. Not 100% sure my memory is correct. For a Z6 you have to swap out mounts, but might not have to for a Y8.
Also, you need to extend wires to the fan switch. Y8 has it on the thermostat cover whereas your stock motor has it on the back above the oil filter.
IAT on your stock motor is on the back of the intake manifold. Y8 has it way up near the filter box. Drill a hole in your intake arm and push it in there or in the silicone coupler if you use an aftermarket and don't want to drill into the metal. Do a search for more details.
Old Jul 8, 2009 | 08:47 AM
WNDOPDLR's Avatar
Thanks guys. This is just what I needed and allexcellent stuff.
bonev911
Mar 13, 2014 09:03 AM
fl1p_m0nk
Feb 22, 2014 07:37 PM
james_piggy
Feb 19, 2013 09:57 PM
tom550
Sep 2, 2011 06:06 AM
tei344
Sep 25, 2007 06:00 PM
