WTT/WTS: COMPLETE Direct Port Nitrous Setup (need turbo/rims)
I Need a good sized Turbo 57trim + or some wheels with Tires. LMK what you have.
This kit is as complete as you can buy. It includes:
All Stainless Lines needed to either install as a Single Fogger Wetshot or Direct Port Wetshot.
All Switches to Arm Nitrous Spray and Turn on Bottle Heater
NX Nitrous Solenoids
NX Nitrous Dumptube
NX Nitrous Pressure Guage with flowthrough Adapter on bottle
NX Bottle Brackets to hold bottle Down
NOS Bottle Heater
NOS Direct Port Nozzles and Distribution Blocks
NOS Direct Port Hardlines Bent for B Series intake manifolds, Im sure it will work with others.
Setup was mounted underneath manifold for stealth look. Lines clear oil cooler, alternator and eveything else. Can also be used on top of manifold for easier access.
NX 10lb bottle with approx. 7lbs of nitrous left in it.
A ton of jets to run Direct Port(funnel jets) or Single shot (Tapered Jets)
Instruction booklet for the NOS Sportsman Fogger Kit (Direct Port)
Instruction booklet for NX EFI Kit (Wetshot)
Inline Booster Fuel Pump and all Wiring and lines to connect it to a stock fuel system in a Civic or Integra.
The kit is as complete as it can come. Bolt on and spray. Only thing you need is a TAP to tap the holes for the nozzles. Sizes are included in the instruction booklets.
You can Safely and legally run this setup at any track because All safety standards are met to run Nitrous on any Track.
EFI kit alone was over $500 NEW. Add on Direct Port, Fuel pump bottle heater, guage and dumptube as well as a bunch of jets.
Asking $600 For EVERYTHING! or Trade for TURBO OR WHEELS!
NX Nitrous Dumptube
NOS Bottle Heater
go bigger lol
