brake problem
Old Aug 22, 2002 | 08:35 AM
kim_2_da_chee's Avatar
Default brake problem
ok, so i just got a EF yesterday.... i was test driving it around the block and i noticed that it is REALLY hard to brake the car to a stop. i dont hear any "metal-to-metal" sqeaking from the rotors so it couldn't be the pads... im just wondering what the problem is... i even tried stomping on the brakes at 40 km/h and it took a long time to stop. kinda dangerous.. need pointers please
oh ya, and i also have a second question..
i let a friend test out the car too, and i noticed white smoke from the exhaust... and quite alot of liquid coming out of a little hole in the exhaust... it seems like water, but smells really bad. burning oil perhaps? whats with the liquid though??
argh, i've got to get this thing fixed for that stupid drive clean program here...
Old Aug 22, 2002 | 08:39 AM
Mr Furball's Avatar
Default Re: brake problem (kim_2_da_chee)
the brakes most likely need to be bleeded, you might have air in the lines that nee to come out.
as for the smoke you might be burning oil and need to find out where and the water might be from condensation in the tail pipe itself and I would not be to concerned about that right now, get the brakes fixed ASAP
Old Aug 22, 2002 | 08:49 AM
Default Re: brake problem (FURBALL B-16)
ic.. thanks for the tips.
wat is the cause of burning oil? leak in the head gasket? "blow-by"??
Old Aug 22, 2002 | 08:54 AM
wronghand's Avatar
If it is truly white smoke then you may have a serious problem. White smoke is usually associated with a blown head gasket. If it is more of a bluish smoke then that would be oil and would probably either be blow by (piston rings) or valve seals.
HTH
Old Aug 22, 2002 | 09:07 AM
Mr Furball's Avatar
Default Re: brake problem (wronghand)
sorry I was thinking blue and read white so disreguard the thing about the oil, if it's white and not blue then you have antifreeze being burned.
Old Aug 22, 2002 | 10:06 AM
****. ya its the head gasket.. i just spoke to a local honda mechanic that i know and he says that he's almost 100% sure that it is a blown head gasket..
well, i already have work to do...
thanks again for ur tips.
J tech
Nov 5, 2010 12:12 PM
JUN.
18
May 9, 2008 08:38 PM
notoriousB
Jul 9, 2005 11:42 AM
hoophype84
Mar 2, 2005 01:28 PM
-Whitey-
Sep 21, 2002 10:06 PM
