Hondata into a CX
Old Jul 6, 2009 | 06:53 PM
slopoke1989's Avatar
Default Hondata into a CX
I am planning on dropping my b16 into my 96 CX Hatch. I have an s300 out of my CRX that I would like to install before I do the swap. Just so I have one less thing to worry about that weekend. I was wondering if a stock p28 map would work or would that throw a check engine light for no v-tec solenoid? Is there a better map that anyone has? PLEASE HELP!!!!
Old Jul 7, 2009 | 02:51 AM
Default Re: Hondata into a CX
Help?
Old Jul 7, 2009 | 03:02 AM
Jackal6042's Avatar
OK, so you are dropping a B16 in your CX... There should be no VTEC CELs because you are going to run the VTEC wiring to the ECU right?
Old Jul 7, 2009 | 01:34 PM
I meant when I run the stock engine for a few weeks on the s300. It has no V-tec and it looks like I only have a stock p28 map to work with, which has V-tec.
Old Jul 7, 2009 | 04:47 PM
Jackal6042's Avatar
You will get a CEL in that case. Actually you will get two (at least), codes 21 VTEC spool solenoid valve and 22 VTEC pressure valve. You don't still have the stock ECU you could run?
Old Jul 7, 2009 | 04:52 PM
thumper64's Avatar
It takes like 2 minutes to swap ECUs. 3 plugs, 4 bolts, 3 plugs, 4 bolts.
Old Jul 7, 2009 | 07:07 PM
I just wanted to put it in and try it out. But i guess I can wait :-(
pip9
May 7, 2006 07:04 PM
crxdx89
Jan 19, 2006 04:08 PM
4NLINE UNLIMITED
Oct 12, 2005 01:37 AM
MassScene
10
Dec 30, 2004 04:21 PM
SLowCrx
Mar 16, 2004 04:35 PM
