crx bogs and acts like rev limiter at 3k rpm
Old Jul 6, 2009 | 06:25 PM
DoubleEx's Avatar
Default crx bogs and acts like rev limiter at 3k rpm
Been working on the car all day long its a y8 i think from like a 99. IT is a crx has rc injectors, skunk IM, crower head. The engine is built. runs rough and is throwing code 10. not sure but when you get going it acts like its hitting a rev limiter at 3k rpm and wont go anywhere until you punch the gas then it will go past it. I cant figure it out plz help.;
Old Jul 6, 2009 | 06:33 PM
Terrible One's Avatar
Default Re: crx bogs and acts like rev limiter at 3k rpm
stock ecu?
Old Jul 6, 2009 | 06:41 PM
DoubleEx's Avatar
yes with vtec controller
Old Jul 6, 2009 | 08:00 PM
D16SiHatch's Avatar
sounds like you need a tune. a vtec controller is not going to cut it. the ecu is making it run uber rich due to it expecting stock 240cc injectors to be there, and you are running something larger.
Old Jul 6, 2009 | 08:14 PM
DoubleEx's Avatar
pressure on gauge stays at 40psi at fuel filter
Old Jul 6, 2009 | 08:31 PM
DoubleEx's Avatar
we will just put the stock injectors back in then. Put them back in when he gets his obd1 set up
Old Jul 9, 2009 | 01:42 PM
DoubleEx's Avatar
Still need help it is doing it all the time now. Could it be the IACV or the FITV?
Old Jul 9, 2009 | 02:01 PM
dephtone's Avatar
If you are throwing code 10 thats IAT (Intake air temp sensor) since you have a y8 running on a z6 ECU, you have to add the sensor to either the intake manifold or on your piping somewhere.
As mentioned above, you need a tune thats why the car is running rough...it's in limp mode thats why it only revs to 3k. Order a basemap from phearable.net or Xenocron and chip your ECU so you can run there car.
I would not recommend running your car unless you want to risk blowing up the motor because tuning has been completed.
Old Jul 9, 2009 | 02:03 PM
DoubleEx's Avatar
the car has been running fine for a year now. put the bigger injectors in a month ago and now this past sunday it started acting up.
Old Jul 9, 2009 | 02:07 PM
dephtone's Avatar
Because you are flooding your motor with the bigger injectors. Did you upgrade from the stock injectors?
How was the car tuned?
Old Jul 9, 2009 | 02:11 PM
DoubleEx's Avatar
yes and never tuned
Old Jul 9, 2009 | 02:15 PM
sixgunsound's Avatar
Originally Posted by DoubleEx
yes and never tuned
Theres the problem. You Cant just throw bigger injectors on it and not have a tune because the ECU still wants to put out the same amount of fuel it would for stock injectors.
Old Jul 9, 2009 | 02:17 PM
dephtone's Avatar
Im sure he was getting absolutely terrible gas milage.
Take the car and get it tuned for the injectors, if not you will damage it, if its not already.
Old Jul 13, 2009 | 08:04 PM
DoubleEx's Avatar
ok he removed the intake and cleaned everything. Still doing the same thing..... Still pondered.
Old Jul 14, 2009 | 05:45 AM
EFing8's Avatar
i had a car do that, the TPS was broken inside. but you would probably get a tps code if that was your problem.
ensang_phamily
23
Oct 17, 2020 07:32 PM
B16Chaser
Oct 1, 2007 12:32 PM
Mini-mEK4
May 31, 2004 06:34 PM
SupaFly_Honda
Oct 8, 2003 07:00 PM
SohcVtecCrix
Sep 14, 2002 07:23 AM
