removing the wiring harness
k , so this is my first time removing one of these , I thought it was just connected to the ECU. and the rest was in the engine bay........ I have wires with little clips going all over uner the dash and I got these little clips holding on some wires that I cant get off for the life of me.... I am so confused am I doing something wrong ?> is there DIY>? any tips?
got a 89 crx si btw...if that helps....
I got a 91 hatch with no rust set up for a b18 ,
I have a rusty 89 hatch set up for my motor ,
91 has no motor or tranny its a rolling stripped shell. I wanna swap over the harnesses , do I need the WHOOOLE thing? like the ones that go to the steering wheel and ac , and all that jazz? cuz if so its a pain in the *** to get to all these little clips... I cussed less when I had to do a tranny in a 78 blazer.
A tranny in the blazer would be a snap lol..
I think your not getting any responses due to lack of info.
From what I gather your removing the engine and ECU harness and want to put it in the other car?
So is there an ecu harness in the car your putting the B18 in already? I guess Im wondering why your going thru all the work of what your doing?
if both the 89 and 91 hatch are the same model type then you will only need the engine harness, and you'll be able to plug it into the existing cabin harness in the 91. however if one is an Si and the other is a Dx for example, then you will need the complete engine and cabin harness swapped over.
TABIAS
10
Jan 31, 2005 10:10 AM
