stiffest suspension for drag racing for the buck???
i did some research it seemed to be the skunk2 drag sleeves and springs what else are you guys using just trying to find something its basically just a drag car
I have to disagree...OTS Koni Sports are valved for 600lb springs and are pretty pricey.
I was surprised to see that the Blox Drag coilovers are inexpensive and work rather well. My buddy Ismael uses these and cut 1.60 60' times pretty consistently. Spring rates are 12k up front and 18k in the rear. they work well if its strictly a drag car.
thanks ya i would consider koni yellows and GC if i had that kind of money im sure the blox arent much cheaper but any others you guys have used or consider
If you want good and cheap find some used ones. Other then that you will have to shell out some cash. Koni's, ground control and blox are fairly priced especally if you had money to put in to a car to need some good springs for drag racing. No need to cheap out on coil's and struts now.
not saying that but compared to stock i have heard the skunk2 drag sleeves and springs are stiff but nothing like custom spring rates open to any ideas though i know its an important part in drag racing so thats why i am open to any input
skunk2 drag springs and sleeves spring rates front 558 rear 1004 is that considerable better than stock?
300 shipped and basically i wont use the the lowering feature on any coilover this car is a sleeper so that prob the best setup i can get for the money it seems
i got skunk2 suspenssion. definitely the best bang for the buck, i think i spent 700 on adjustable springs, shocks and LCA's, HUGE difference.
Having 1000Lb springs in the rear will help reduce "squat" under hard launches and shifts.
