need help its a lil more than a miss
okay to start ill give you some history on this car it is a 00 ek and had a normal single cam in it then some kid put somethin else in it and blew it up then me and my buddy got it and put a 93 single cam in, which in turn was obd1. anyhow so now it runs but only on two cylinders, checked spark and have it from dist. to sparkplug, checked injectors and found the two left ones were not working so i swapped em with the right two and problem didnt follow. so you dont need a noid light to tell you the two left injectors are not getting pulse or signal... so yea any help would be great if anyone has seen this before
car somewhat smooths out while driving and checked ohms throught wires to makes sure they arent separated anywhere before injectors.... leaning towrds ecu, still lookin for any help if any of you fellas dealt with this before
it sounds dumb, but are you POSITIVE the firing order is correct? reason i ask is my buddy had this same exact problem after his swap, thinking it was the injectors so i went over looked at it for a minute switched the wires to where they needed to be and voila.
cns21
12
Aug 1, 2009 07:19 PM
D15Bbigred
Mar 8, 2006 06:18 AM
gunner6696
Dec 17, 2005 10:07 AM
gtarwiz
12
Apr 11, 2005 10:19 PM
