SOHC ZC swap questions
I have a 90 ef hatch with a blown d15b2. Im trying to put a motor in this thing and cant seem to make my mind up. I really dont care about power to much, I just need a car to drive around till my DSM gets better. I was looking into a SOHC non-vtec ZC to throw in there. I have been searching around to see what all it would take to put it in there, the only thing I came up with is to use a SI ecu and that should be it. That dont seem right, I think I would have to wire it for MPFI some how. Does anybody have any info on this swap to help me out with it. I have about 600 bucks to work with on this, so the lower the better. Thanks.
yes, you would need to convert from DPFI to MPFI - the actual swap of the SOHC ZC non-VTEC is the same as if you were swapping in a D16A6 from 88-91 CRX/Civic Si
So the engine exchange is easy, bolt up and move on. Then to the DPFI to MPFI I need to, mate parts of a Si harness to my stock DX harness(needed for injector plugs, injector resistor box plug, and distributor plug), Install SI ecu, do all of this http://www.geocities.com/teampimports/fuelinj.html, and I should be good? Also the injectors have the harness still plugged into them, but the wires are cut, I can use these so I dont have to get a SI harness correct? And one more, can I just put the d15b2 intake on there for now and drive that around? I want to swap for the MPFI but I wont be able to do it when I get the motor?
or am i missing something...?
Dude, I heard alot of crap for suggesting the same thing here on h-t awhile back, but I've done it and it works. good luck
essay0ns
Apr 17, 2015 05:52 PM
