Need help installing 2nd cigarette adapter **PIC**
Old Jul 6, 2009 | 09:15 AM
kroze's Avatar
Default Need help installing 2nd cigarette adapter **PIC**
Does anyone know what is the hole size for a standard cigarette plug? I want to drill & install a second cigarette plug right here and I don't know what tool do I need to cut the hole.
Old Jul 6, 2009 | 09:40 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: Need help installing 2nd cigarette adapter **PIC**
If its the same hole size as the one on the left. Just measure it and mark the Measurement to were you want the hole. Or trace the hole on a peice of paper and trace it on the the spot were you want a cut it out. Run 12 volt power if you want it to work constant or tag it to the accesory wire if you want it switched. Make sure you fuse it. and then ground it. DOne
Old Jul 7, 2009 | 05:23 PM
emrock32's Avatar
New User
you could drill it out smaller and use a dremel until it fits.
Old Jul 7, 2009 | 07:02 PM
95jdmej2's Avatar
Or you could get a step bit and drill it out till it fits.
Tom B
Jan 24, 2016 05:36 AM
tnxx
Welding / Fabrication
33
Apr 17, 2012 03:10 AM
xdumbox
Oct 5, 2006 06:14 PM
hondaguyef
Apr 17, 2005 04:16 PM
simplegreenmachine
Dec 21, 2002 05:38 PM
