94+ Integra seats in a CRX instructions?
1. measure how far apart ur stock brackets are from each other.
2. take off the outer bracket on the Integ seats.
3. put the outer bracket off the crx seat at the apporpriate distance (keep in mind that you might have to make new holes and use bolts with lock washers and nuts to make sure its secure...its tricky but not too hard)
4. shorten the wire thing that pulls the adjuster thing on the outer bracket then reattatch and make sure it pulls it well enough so you can adjust.
5. reinstall the seats...only the front 2 and rear outer bracket will be bolted in but it holds on tight.
i have done this for 2 different cars already and no extra drillin onto the car...the only drilling i did was holes on the seats and bracket where i had to bold the outer bracket to the seat. the seats that were in both cars were very sturdy and tight...actually i could even say that it was tighter than my stock CRX si seats in my car. hope u guys can understand these instructions...i dont know if theres a better way to do this but i know this is the best way i could find out without drillin holes into the bottom of the car. let me know how things go, GOOD LUCK!!!
hondaguyef
May 26, 2005 07:30 PM
crux131
Jan 31, 2004 11:41 AM
camera obscura
Mar 25, 2003 08:04 PM
