Crx dash installed..now horn,cd player/radio dont work?
Old Jul 5, 2009 | 10:36 PM
boostedefhatch's Avatar
Default Crx dash installed..now horn,cd player/radio dont work?
like the title says. i installed a full crx dash into my 91 civic hatch and now my horn, radio/cd player, and cig lighter dont work, there is one plug on the lower harness that is not plugged in so there's 3 plugs one that runs to the cig lighter thats plugged, and the one that runs to the heater is in also i cant remeber were the other one goes. any help is greatly appriciated i also checked my manual for wiring schimatics
Old Jul 5, 2009 | 10:42 PM
dacrxguy's Avatar
Default Re: Crx dash installed..now horn,cd player/radio dont work?
Make sure that the ground found in the dash to the body is connected
Old Jul 5, 2009 | 10:44 PM
thats what i first thought it was does it need to be that same special bolt, the one its bolted to is like gold and i did ground it but nothing
Old Jul 6, 2009 | 07:45 PM
bump please help! it worked before i did this! the ground is connected, checked for blown fuses none.
Old Jul 6, 2009 | 07:53 PM
come on guys 50 views 1 response, there is 1 plug thats not plugged in. theres the 3 on the lower harness 1 goes to cig lighter, then the stuff for the deck then there is one more that goes to ?????
Old Jul 6, 2009 | 08:02 PM
pumpkin129's Avatar
how many wires are in the plug and what color are the wires?
Old Jul 7, 2009 | 06:05 PM
here is a pic of the harness that runs down to it. i have all the radio ones plugged to the deck. what is the one wire/plug go to ????
Old Jul 7, 2009 | 06:07 PM
please help its killing me!!!! my deck dont work, my horn dont work, and my cig lighter dont work only the clock on that sectuion works. and the underdash ground is grounded please help i checked fuses!
Old Jul 7, 2009 | 07:16 PM
bump please help
Old Jul 7, 2009 | 08:00 PM
help me please! bump
Old Jul 7, 2009 | 11:58 PM
122 views come on someone
Old Jul 8, 2009 | 09:42 AM
dephtone's Avatar
Is your fuse blown by chance? I know something so small, but I didn't see if you had checked it or not.
Old Jul 8, 2009 | 10:39 AM
yes i checked my fuses even the one on the back of the deck unless i am missing one?
Old Jul 8, 2009 | 10:42 AM
dephtone's Avatar
Just the one underneath the dash that controls the radio cig lighter etc.
Old Jul 8, 2009 | 09:30 PM
lunalink's Avatar
hmm...ill check it out tomorrow when i get back from work..im going to install a new stereo so ill check where that plug goes since im going to have that spot open..but there is 1 more plug by the cig. lighter.
Old Jul 9, 2009 | 01:16 AM
ok ya man i would totally appricaite it if i could find out what it goes to it might be my problem
checked those said it about every post my fuses are good. thanks for ur reply any other options
Old Jul 9, 2009 | 01:34 AM
dacrxguy's Avatar
did u connect everything in the under dash fuse box and what wiring harness are you using the old civic one or the crx one
ps ill look for that plug tomorrow but i dont remember seeing it
nvm i remember now it goes to a little black box in the back of the dash i dont know what it is for but i will try to find out
Old Jul 9, 2009 | 05:36 AM
redflaredcrx90's Avatar
there is a lil 4 wire relay that goes there
Old Jul 9, 2009 | 11:54 PM
do u have the relay number?
do u have relay number
Jap_Spec_Imports
Nov 14, 2007 10:31 AM
JMarv20
Audio / Security / Video
Jan 17, 2005 11:05 AM
cbirchmore
Jan 6, 2005 07:44 PM
sshaikh01
Mar 10, 2003 05:48 PM
