Need help with minime asap
Old Jul 5, 2009 | 10:14 PM
twodoordime's Avatar
Default Need help with minime asap
Im doing a mini me on a 1999 civic cx with stock d16y7 and im putting a d16y8 head on it. Everything that i have read says that I have to cut the orange wire on the iacv and reverse the other two wires, but why cant I just run the d16y7 throttle body and iacv so that I dont have to cut any wires. Besides this wire modification and adding wires for knock sensor, vtec, and vtec pressure. Will i have to do any other wiring changes.
Old Jul 5, 2009 | 10:22 PM
Adam_b16a's Avatar
Default Re: Need help with minime asap
You cant run the y7 iacv and manifold because it utilizes a 3 wire iacv and the y8 ecu utilizes a 2 setup.
Old Jul 5, 2009 | 10:25 PM
Ok so the ecu is the problem with running the y7 iacv and throttle body not the actual iacv itself correct?
Old Jul 5, 2009 | 10:29 PM
Adam_b16a's Avatar
correct.
CivicPride97
Aug 1, 2009 12:01 PM
matt45
Apr 11, 2009 11:52 AM
96jdmciv
Oct 29, 2008 04:25 PM
faxshatch
Apr 14, 2008 11:53 AM
bambbrose
Oct 10, 2004 08:13 AM
