96 Honda Accord VSS replacement
Old Jul 5, 2009 | 07:52 PM
tt3's Avatar
tt3
Default 96 Honda Accord VSS replacement
Hi, I have 1996 Honda Accord EX car. I need to replace speed sensor(VSS). But I couldn't find VSS location. Where does speed sensor locate? How to replace it? Do you know any about 96 Honda accord VSS replacement procedure with pictures? Thanks a lot!
Old Jul 5, 2009 | 08:51 PM
19Accord97's Avatar
Default Re: 96 Honda Accord VSS replacement
I THINK it is on the tranny housing but am not sure.
Do a search and you should find alot more info.
Old Jul 5, 2009 | 08:55 PM
TheMuffinMan's Avatar
He knows where you live!
It's just two or three bolts that hold it on. For the manual car it's almost directly below the intake arm on top of the transmission, should be one of the only things with a wired plug going into it. You will have to remove the intake arm and have a ratchet extension/skinny arms to get down to it.
Do a search I know it's been discussed in depth.
Old Jul 19, 2009 | 11:50 AM
foozer's Avatar
New User
Thanks for all the threads on this subject. My 96 Accord/4Cyl has only one
bolt hole on the VSS, on the tranny just opposite the right front tire.
I have a new VSS now, but still have a CEL, no speedometer and no cruise control.
(I have checked all electrical connections, inside and out. Self diag indicates still
a bad VSS (Code 17) but it is new.) Odd.
I have searched several threads but I am not finding any specific ideas
with regard to these symtoms.
Still looking. Thanks.
Last edited by foozer; Jul 19, 2009 at 11:55 AM. Reason: spelling, more action taken noted
mrbangchang
Feb 10, 2015 08:34 AM
dachinkrac3r
Feb 9, 2006 06:48 PM
gjohnson4
Jul 28, 2004 01:50 PM
