where the rubber meets the steel (fuel line)
Old Jul 5, 2009 | 07:36 PM
double b from wv's Avatar
Icon2 where the rubber meets the steel (fuel line)
okay, so im getting ready to put my old 91 accord back on the road. the biggest issue is the leaking fuel line. today i got under it to investigate, and this is what i ended up with.
there is a little line that comes out of the larger line, which runs down the underside of the car. that little stub had a fitting, which broke off in the union. on the other end of the union is a rubber line with a steel end.
so, any ideas on how i can fix it? i have fuel line tools, but i dont know if its a good idea to but and splice between these two lines (do away with the union). i havent measured the diameter of the lines yet, but i think the ones that go into the union are different diameters... but i could be wrong. i dont really want to drop the tank and everything, but i might have to to get this done right.
any advice is appreciated.
Old Jul 5, 2009 | 09:01 PM
bseriescrxsi's Avatar
Default Re: where the rubber meets the steel (fuel line)
you should be fine as long as the ends have the bulge you could hose clamp....as i have a modified fuel like on my accord(for length) and the stock end was cut off and then hose clamped back on minus the fancy gold fitting around it
Old Jul 8, 2009 | 03:53 PM
doing away with the union isnt a real concern. what im wondering is if a compression fitting will work if the line diameters on either side are different from one another? i mean, there is a pretty big difference between the large diameter line and the smaller metal end on the rubber line that goes up to the pump. so i guess i would just have to buy one that will fit the larger one, and flair the hell out of the smaller one? and get an end to fit each one snug?
here are a few more pics, if you wanna check them out.
pic 1
pic 2
pic 3
Old Jul 8, 2009 | 08:03 PM
goodluck with that...yea flaring it might be ur best best....or take it n have a hydraulic place make up a line
B_Swapped93
Apr 4, 2019 10:02 PM
95accordian
Jul 19, 2016 08:35 AM
Marcg611
Aug 10, 2010 05:24 PM
IMSTOCK
Aug 23, 2004 08:46 PM
biglew
Dec 29, 2003 08:45 PM
