benefit to larger bore?
Old Jul 5, 2009 | 07:30 PM
8VEYBEYB's Avatar
Default benefit to larger bore?
what would be the benefit of changing to a 76mm piston as opposed to a 75? I want low compression for turbo but my cylinder wall is pitted so I must bore n re-hone. also gotta get new pistons....
Old Jul 6, 2009 | 06:02 AM
8VEYBEYB's Avatar
Default Re: benefit to larger bore?
anyone?
Old Jul 6, 2009 | 06:25 AM
dephtone's Avatar
You can run 75.5 bore if that gets rid of your pits and you can run vitara/eagle setup. perfect for boosting a D series.
Old Jul 6, 2009 | 06:28 AM
DrewZH's Avatar
The only real benefit of a larger bore only comes in crazy all motor race applications. If you run huge valves you may run into a "shrouding" problem where the bore clearance is too small for air to flow nicely around the valve. A larger bore helps in this application because air can flow from the port to the chamber better.
You'll see a small increase in compression ratio too assuming everything else is the same except bore size. Its nothing really to be concerned with, the change isn't very much.
Old Jul 6, 2009 | 07:08 AM
8VEYBEYB's Avatar
I appreciate it , how much should I expect to pay for boring/honing ? Ive only done honing before and that was 25$
eg94life
Apr 7, 2014 08:06 AM
michaelprice83
10
Sep 12, 2010 09:10 AM
earl
Mar 21, 2003 09:09 PM
riceboy
Oct 19, 2002 08:19 AM
