A little vtec dilemma! I think Video inside.
Well vtec doesnt seem to kick in in 1st gear. 2nd, 3rd, and 4th it cuts off right around 5500rpm stales and then kick in. 5th gear vtec kicks in perfectly fine as u see in the video...what you guys think? Ecu? Dizzy? Etc..?
[IMG]
[IMG]
i noticed you have the CEL shift light, which means you either have an s200 or s300, what i've noticed with chipped ecu's (especially hondata) if everything isn't picked up by the ecu, strange things happen
and sort of off topic: i noticed you're from slidell were you at the lakefront carshow?
first question is which engine do you have?
no sir i stayed in slidell for awhile right before katrina but moved back to the N.O.
Don't use a p28 it will run like crap. See if you can get a stock p72 (GSR) ecu.
Hook up a little wire with a led on it, to ensure vtec isn't working. VTEC is supposed to be a smooth transition between the lobes.
cool...never thought of the led part..thanks i'll go try that out today
TurboIntegra
Dec 15, 2002 05:06 PM
TurboIntegra
Dec 15, 2002 12:57 AM
