rpf1
Old Jul 5, 2009 | 06:42 PM
ecko_3420's Avatar
Default rpf1
I have a chance to pick up 16” x 7” Enkei RP-F1 35mm offset. 4 x 100 lug pattern. Would these fit ok on my civic? I have a 97 ek hacthback lowered on tanabe springs. Just not sure on the 35mm offset. THanks guys..
Old Jul 5, 2009 | 06:56 PM
katzenjammer84's Avatar
Default Re: rpf1
It'd likely depend on how much camber you're willing to run, and how low you are.
Old Jul 7, 2009 | 11:00 AM
DrZFiNeSt's Avatar
Default Re: rpf1
You should be good.What size tires do you plan on running?
Old Jul 7, 2009 | 11:27 AM
ecko_3420's Avatar
Default Re: rpf1
205-50-16
Old Jul 7, 2009 | 11:34 AM
Andy_EJ8's Avatar
Default Re: rpf1
it should fit, but I would run a 205-45-16 tire.
Old Jul 7, 2009 | 12:28 PM
DrZFiNeSt's Avatar
Default Re: rpf1
^x2 why not 205/45/16?
Old Jul 7, 2009 | 02:16 PM
ecko_3420's Avatar
Default Re: rpf1
cuz its gnna come with the rims...its still has about 70% left...
Old Jul 7, 2009 | 05:37 PM
UncleD's Avatar
Default Re: rpf1
Originally Posted by ecko_3420
205-50-16
These will rub with that offset, and it's the wrong size for your car anyway. If I remember correctly, the Tanabe springs don't lower the car much...you could probably run the correct size tire(205/45) with correct alignment angles and be ok.
DAGUIRRE23
May 13, 2016 09:02 AM
michaelhhdk
May 8, 2015 11:20 PM
tnemelc
Apr 29, 2013 10:37 AM
whatcivic
12
Apr 8, 2005 02:34 PM
RTW DC2R
Feb 3, 2003 08:54 PM
