Honda Accord 97, Took Out Battery Temporarily now it wont Crank/Start!
Ok our Grand Caravan had battery problems and we wanted to eliminate the battery or alternator as the issue so I took out the battery for my accord (factory alarm was disabled at the time) and tried it in the Caravan and did our readings, and realized the wrong battery was put in the Caravan when we bought it. So I put our Honda battery back in and now the car wont start at all!
Its weird because no lights at all come on. The only thing that works is the horn and the emergency lights. Nothing else works. The alarm light isnt flashing, the car doesnt crank at all, its like the whole electrical system is shut down except for the horn and emergency lights. I have been thinking that maybe the alarm system for the car reset when the battery was taken out but wouldn't the car dashboard and radio come on at least (even if the car doesnt start)?
ANyone know what might have caused this? I appreciate you guys help as this is my main car and I got work tommorrow!
Jump the battery and get it tested AT aUTOzone before they close may have caused a cell to go bad by putting it in your caravan?
I tried to jump start the accord and it doesnt work either, does the same exact thing it does when I just try to start the car regularly. None of the lights come on, it doesnt crank or anything
Even tried another battery we have lying around that actually worked with the Grand Caravan and same symptoms. Its definately not a dead battery.
check the under hood fuse box big 60A fuse l;abeled battery....when you put the battery back in you couldve blown the fuse(the emergency lights would still work in this scenario..not sure about the horn but most likely)
Mrflip99
Sep 9, 2015 07:36 PM
mr_munro
Dec 6, 2013 06:23 AM
Junkyard Dogg
May 7, 2006 05:34 PM
