Weak spark
Old Jul 5, 2009 | 06:29 AM
Ed ke6bnl's Avatar
Default Weak spark
I was given a Honda 1992 accord lx. It has a week spark at the coil and I got now spark at the spark plug wire, it has a new dist. coil looks original. Where do you suggest I start going. thanks ED
Old Jul 5, 2009 | 07:25 AM
GhostAccord's Avatar
Default Re: Weak spark
I would suggest that you get yourself a Helms manual for the 90-93 Accord. Then you will be able to troubleshoot the ignition system properly.
Starting at the coil would be my suggestion. With an Ohm meter check the resistance on the primary and secondary coil windings. Sorry I don't have a 90-93 helms manual to give you the step by step.
Old Jul 5, 2009 | 07:50 AM
Ed ke6bnl's Avatar
I just picked up the car 7-3-09 and will pu a manual Monday, and go from there thanks for the suggestion ed
Old Jul 5, 2009 | 08:02 AM
Yeah I didn't mean to come off as a dick. Electrical trouble shooting and replacing those lower o-rings in the spark plug tube both require the use of a manual. Much easier than trying to sift through posts on here.
Good luck with your Accord
Old Jul 5, 2009 | 08:06 AM
Ed ke6bnl's Avatar
manual will be picked up Monday, picked up car Friday I don't live near any shopping center or many stores so will get one on the way back from work Monday ED
gole
Honda CR-V & Element
Dec 22, 2014 04:56 PM
michaelb15
Dec 6, 2012 01:42 PM
asianalbutt
Dec 19, 2005 09:11 AM
Michalob234
Dec 29, 2003 06:48 PM
2000Accord5sp
Nov 17, 2003 11:47 PM
