Need some help... new to the scene
name is thomas, im putting togeather a 89 ef hatch i pick up with a OBD1 D16Z6 SOHC VTEC
for $300.00 for both and i need a trans, pretty sure i found one from fellow HT member, was wondering as far as wiring goes to make this work does anyone have know how on what i need to do to get this swap done? i will be very thankful for any help anyone has to offer me.
you will need to convert your stock wiring harness to MPFI then either make or purchase an obd0-obd1 conversion harness. use the clutch/pressure plate/fly wheel combo for the trans you get.
part's you'll need to convert to obd1 are the z6 dizzy, p28 ecu, 4 wire o2 sensor, and plugs for the corresponding items (dizzy, male plugs to plug into the ecu, o2 sensor plug, and obd1 dizzy plugs to repin).
Justinleexxx
21
Aug 19, 2014 12:40 PM
carlosjdmcivic
Jul 11, 2012 01:56 PM
puertoroc7976
Oct 10, 2006 05:19 PM
