Need help with rod bearing clearences....?
Hey HT
I am confused on my rod bearing clearences after i plastigaged them and got this......
Bearing clearance on rod #1- .001in
Bearing clearance on rod #2- .001in
Bearing clearance on rod #3- .001in
Bearing clearance on rod #4- .001in
Somethings fishy to me, its either my plastiguaging skills suck or the clearences are all the same acrooss the bearings..?
I used the green plastiguage strip that said .001 to .003 inch clearance range.
So no one will tell me anything
This leads me to think that the bearings i got are to tight.........? And that i will have to order some biger bearings.
Hey HT
Yeah i understand that its the fourth of jully butt no need to be all mad about it
If youre not gonna help then no need to post.
I did more resherch and came up with what i posted in my second post
Im just really anxious to get this thing up and runing.
Has been down for almost 2 weeks.
Thanks guys
Wel theyre black on the botom of the bearing.
They came standard wen i bought some type r pistons with rods and standard rod bearings...?
I have a sett of used bearings that came out of the engine(has 124k miles on it) to put on some new standard rod bearings..?
Your plastiguage isnt too old is it? Ive heard of the stuff getting old and not keeping its "squish".
If those measurement are accurate, then yes your bearing clearances are too tight.
What color do you get when you match up the crank and block codes? Thinner than green?
Here we go again so on fourth of july u wont use ure brain to help out a person in need.
Thanks guys
Thanks guys
There is no collor on them
The codes on the crank and rods will determine what color oem bearings you should use.
