B20 EF Front end conversion questions???
Old Jul 4, 2009 | 07:04 AM
hondafleet82's Avatar
Default B20 EF Front end conversion questions???
What's good guys,
About to throw my B20 Vtec into my 91 EF. I am going to buy a US SiR Carbon Fiber hood from VIS. Any brought one before? I believe they specify US SiR because it will fit on a stock USDM crx. This way you can get the clearence of a SiR hood without doing a full JDM front end conversion. ANY IDEAS?
Old Jul 4, 2009 | 07:24 AM
border919's Avatar
Default Re: B20 EF Front end conversion questions???
this is confusing.just get all jdm ef8 front end components. idk what you mean by usdm ef8 sir front bumper.
Old Jul 4, 2009 | 07:33 AM
I edited the post. This should make more sense.
Old Jul 4, 2009 | 08:48 AM
DCRB's Avatar
would you be refering to the zc hood? the one w the hump on the drivers side??
Old Jul 4, 2009 | 08:52 AM
hondahustle's Avatar
I understand what you are asking. Yeah that would work, but you don't need to do a JDM conversion to put a B series in our cars. I have a 91 civic hatch and I didn't have to change my hood or bang the hood up or anything. I think if you use hasport mounts there should be no issues.
Old Jul 4, 2009 | 09:25 AM
No, it's not a ZC HOOD. Im running a b20 vtec. Using hasport mounts. They have a alternator relocation kit but I don't want to use it. Search eBay for SiR carbon fiber hoods & you will see that US SiR hood.
Old Jul 4, 2009 | 09:28 AM
I know a B16 or B18 would fit. I'm pretty sure it's the height of the B20 block that causes the clearance issue.
Old Jul 4, 2009 | 10:29 AM
passwordjdmef9's Avatar
Originally Posted by hondafleet82
What's good guys,
its the same hiegth. same motor clearence. usdm n jdm the same. the b20 will fit in their even with stock hood, no problem
Old Jul 4, 2009 | 10:40 AM
border919's Avatar
try it out.no reason to spend money if you dont need to.
Old Jul 4, 2009 | 11:58 AM
.Manny.'s Avatar
Touching My Member
The valve cover will rub slightly on the right side just before the area that covers the cam gears...simply trim the webbing on the hood and you will be ok. save the cash and buy something that will help the motor make more powwa!
Old Jul 4, 2009 | 12:52 PM
gibsanez's Avatar
A B18 uses the same block as a B20.
Old Jul 4, 2009 | 01:29 PM
lunalink's Avatar
^ JDMcarboy has a spray.. thats all it is can goes for about $20-30..
Old Jul 4, 2009 | 03:29 PM
By b series I meant B20 lol. A b20 should fit in no problem with hasport mounts.
Old Jul 4, 2009 | 08:36 PM
dephtone's Avatar
Both My B16 and b20 series fits fine under my stock hood and under my sir hood without any problems
project504
Jan 7, 2009 04:43 PM
tommy.
Jul 8, 2006 01:43 AM
91jdmzc
10
May 22, 2005 05:45 PM
speed_racer012
Mar 10, 2004 04:23 PM
SuperCivic
20
Aug 24, 2002 08:46 PM
