I need help B18 gsr build!
I need to know what anyone thinks about CTR pistons? The brand is pct good brand or what?I'm running stock rods will it hold for reasonable street/track car every day driver? i got b18c5 head .05 over sized valves really mild port job BC stage 3 cam shafts good head or needs more work? should i run stock head gasket or thicker? how high will my compression be i really dont want alot or hp but reasonable for every day driving track use? and will it hold if i spray nitrous? any help would be great?
I'd would rather use some ITR or PR3 pistons for that build. You're only running BC3 cams, which don't require a High CR that the CTR pistons would yield. Play on the link below to see what CR you'll have with the different types of of pistons. And no the PCT pistons are not the manufacturere of CTR pistons, they are the style or model number for the CTR pistons. For example, P73 pistons are ITR pistons, P72 are GSR pistons, hence PCT are CTR pistons.
Look here for the compression calculator.
www.zealautowerks.com
I meant to spell it like CPT brand pistons cuz the sell them on h motors online i just bought mine off ebay and i think im just going to run a .60 mill head gasket but i just dont know what my cr will me cuz with a stock one it will be way to high like 12:10.1 im not tryin to run that thats like race gas status but any more help and anything for sell and advice would help? thanks
Way to think ahead and plan your build before you start buying parts....Now you want to know how to band-aid them all together so it'll work....sad.
If you want to know about PCT pistons, try doing a search on here or Google them.
Yes they will, but how did you figure your compression? Calculating it can be very inaccurate if you don't have all the proper variables known (Piston to deck height, combustion chamber volume, etc...). Not to mention you have oversized valves. Are they flat top? Or do they have the same dimple that stock Honda valves do?
Go to http://www.zealautowerks.com/ and you can find out what ever your cr will be
You really have no clue as to what you are doing, so I suggest you stay off the juice until you do get some more understanding, that is unless you got deep pockets to buy a new motor.
This thread is a great example of what we have all been ranting about. Pull your head out of your ***. You're asking for help in a forum, people are trying to give it to you, but you're rejecting it because it's not what you want to hear.
28 post's left.
28 post's left.
it might not of been what u wanted to hear but its the truth the ? u should of asked was i brought ctr's and was wondering if i should sell them because im running (your cam's) and you want to spray it but also dont want to use race gas.
If i was you i would sell those ctr's and go with itr's if u want oem or like wiseco or somthing
this guy cracks me up! hes awesome, hes just keepin it real!
Dc2slow23
Mar 23, 2015 04:53 PM
mario_pic
Apr 23, 2009 10:47 AM
jdmjeff
11
Nov 18, 2005 04:34 PM
