how to remove crank key, pully came loose?
Old Jul 3, 2009 | 01:46 PM
oranginal's Avatar
Default how to remove crank key, pully came loose?
Basically my crank pulley got loose and ate away at the key that's in there.
I was able to get the key out after removing the pulley that the timing belt connects to.
not sure if the key normally slides out but i got it out this way
Old Jul 3, 2009 | 05:18 PM
philafelman's Avatar
Default Re: how to remove crank key, pully came loose?
yes, the key just slides into the groove, then the pulley goes on it.
Old Jul 3, 2009 | 08:20 PM
pr0honda's Avatar
you should check to see if the crank pully shakes around when u put a new key in there.. i seen one recently that was totally ruined.. needed a new pulley since the other one was completely warped..
Old Jul 3, 2009 | 08:36 PM
milehigh32's Avatar
where did you find a new key i need one myself
Old Jul 3, 2009 | 09:11 PM
you should be able to get it from honda.
Old Jul 6, 2009 | 08:38 PM
rothgar1's Avatar
New User
2003 icivic lx 1.7 l How to adjust alt a/c belt ac is weak2003 icivic lx 1.7 l
Old Jul 6, 2009 | 10:02 PM
I AM WEASEL's Avatar
Buy a helms or start your own thread in the proper forum. This has noting to do with all motor or the original topic.
EdSales
Jan 15, 2012 02:01 PM
sayanything
Sep 5, 2010 04:28 PM
oranginal
Jul 3, 2009 02:20 PM
Jabinya
Aug 28, 2007 06:50 PM
street_ride14
May 13, 2007 04:35 PM
