b16 swap what ecu to run in obd1 eg
i plan on swapping a b16 into my eg hatch. ive read up and found most my questions but i want to be positive on a few things. mine is obd1 so when i swap in an obd1 b16 and use the hasport wiring harness what ecu will i run? also what radiator should i use?
thanks, and if someone has a page that covers everything on an obd1 b16 into an obd1 eg that would be cool too
if your cars wiring is obd1 use a p30 ecu or you can use a chipped p28 with a b16a2 map.
as for the radiator im not sure i used the oem civic vti b16a2 one but im pretty sure other eg ones will work.
