jdm dohc zc
anyones help is needed. i have a jdm dual overhead cam zc and the last owner spun a bearing and slightly bent the rod. the owner continued to drive on the bad bearing and it ended up scratching the crankshaft pretty bad. i am going to go get my crankshaft resurfaced hopefully. the question i wanted to ask is can i put d16a6 bottom end internals into this zc block. bearings rods pistons and crankshaft. if not is there an alternative because parts for this zc are very hard to find. anyone is welcome to post there set up for their zc and if you may have parts for the zc to sell that i may need pm me. thanks honda-tech
