Boot Latch warning light
Hi Guys,
This is my first post here (after lots of searching) so please don't bite my (virtual) head off.
I cannot get my boot latch warning light to turn off, I have power to the latch but even if I unplug it and ground it manually nothing happens, I have taken the latch out and the switch is touching/not touching when it should be. Any help is much appreciated
Thanks in advance
oh and I just wanna say thanks for all the info and links I have used especially fixing leaks.
Thanks in advance
I think hes talking about the hatch open light on the cluster. I thought that latch didn't have power. I thought it just completed a grounding circuit and the light on the cluster already had power. You may have a break in wire somewhere between the latch and cluster. You may want to pull the cluster and do a continuity test to see.
ok what I meant was if I pull the connector apart and put one end of my tester into that and the other end onto the main ground for the rear lights it makes a curcuit. I have also tried to go from the connector to ground with a piece of wire, no joy. looks like i'm going to have to pull the dash out.
Edit: jlicrx - I must have been typing as you posted
if you unplug the connector and the light stays on, you have a short somewhere in the ground wire between the cluster and the switch - if you unplug it and the light goes off, you have a bad switch
just worked it out. I have a clifford alarm that was installed when I got the car they have rewired the boot warning light to a new switch under the bonnet (had a dodgy bonnet catch and haven't had the bonnet closed properly, I have a lot of work to do on her before she is road legal)
Thanks for all your help.
Mods feel free to close this thread
junior_tm
May 6, 2008 08:02 PM
