Electric Speedo Conversion help...
So I have been looking around and I'm getting confused. I just bought a 99 si gauge cluster that I'm putting in my 89 CRX. I have a B16 in it but I used my cable speedo. I know that I have to do the electric speedo conversion to make the speedometer work but I'm confused. Where would I buy the electric speedo? Could some one better explain this whole process to me?
Thanks
Thanks
you can use am electronic vss from a 92-95 civic. it hooks up like so..
you will splice the signal wire from the vss into the orange wire at the cluster, and then also into the yellow/white wire so that the ecu will know the speed.
this will also prove helpful for you i imagine
http://www.tuner-junction.com/TJForu...88-91-crx.html
Thanks. That helps a lot. Is my ecu confused now because I am using the old cable speedo and its not getting a signal?
01, 91, b16, civic, conversion, converting, crx, electric, electrical, gauge, honda, si, speedo, speedometer, sppedo
