304 AND 316 on mani?
Old Jul 2, 2009 | 05:46 PM
mkehler's Avatar
Default 304 AND 316 on mani?
Are there any issues that would arise with using a (sch10) 316 collector, and the rest of the manifold (sch10) 304 weld els? If not, simply use 309 filler and rock n roll?
thanks
Matt
Old Jul 2, 2009 | 06:01 PM
downest's Avatar
Default Re: 304 AND 316 on mani?
I don't think so, but I'm not certain. I know I've seen a ton of manifolds out there with mild flanges and 304 collectors/weld els/tube.
Old Jul 2, 2009 | 09:31 PM
k24em2's Avatar
Use 316 rod.
Old Jul 3, 2009 | 04:07 AM
AFFIRace's Avatar
I think you'll be alright with the different alloys. The one thing I would be concerned with is the sch 10 collector. I'll be honest and say my personal manifold cracked at the turbine flange. The runners held up great, it was just the collector that had to be welded and braced. It's too thin. Just my experience.
Old Jul 3, 2009 | 07:35 AM
ManBearPig4silly's Avatar
Use 316 filler on the 308 to 316 welds and 309 on the carbon to 308 welds and you will be fine. Why use the more expensive 316 anyway?
sch10 will be fine as long as it's welded properly.
Old Jul 4, 2009 | 05:08 AM
CSaddict's Avatar
I have never seen a properly welded sch 10 collector crack ever.
Old Jul 4, 2009 | 05:57 AM
onefstek's Avatar
Use 347 rod. Will give you a much stronger weld.
Old Jul 8, 2009 | 06:16 PM
mkehler's Avatar
thanks guys! good info here..
Old Jul 9, 2009 | 01:08 PM
GrayAutoDesign's Avatar
Ditto on the 347 rod
Old Jul 9, 2009 | 09:48 PM
stevenkacey's Avatar
316 filler fr the 316 to 304 is to spec
.john.
Welding / Fabrication
Mar 4, 2008 06:52 AM
AH1078
Feb 10, 2007 01:35 PM
bunnyrabbit
Sep 14, 2005 09:39 AM
.David
23
Dec 5, 2004 06:32 AM
