Stock sub in type-s...
Old Jul 2, 2009 | 03:20 PM
HondaGSX's Avatar
Default Stock sub in type-s...
Ok so i'm mainly talking about the plug that connects the stock sub in the trunk and the wiring harness in the trunk... A friend of mine says that you can un-plug the stock sub and buy a plug/adapter and use that to hook right up to a new sub. Does anyone have this set-up or know if this even exists? I'm not looking for anything crazy I basically want to use my stock amp and the stock headunit and still get alittle more bass. Let me know! Thanks -
Old Jul 2, 2009 | 04:16 PM
chacabaca's Avatar
Default Re: Stock sub in type-s...
you could find a plug, or just cut it and extend the wires to plug into a sub. the only problem is that the power being supplied to that sub, which is roughly an 8in. woofer, is that the power level is really low, and u risk damaging the stock bose amplifier and/or the aftermarket sub. the best thing to do is to purchase a line output converter, tap that off of the sub speaker wires. this will convert the signal into a set of rca outputs. then u can purchase an amplifier, run the necessary power, and then u can safely have a subwoofer with its own dedicated amp. it'll sound great, and u can use the bass control on your stock deck as a subwoofer gain control.
Old Jul 2, 2009 | 05:53 PM
96shox's Avatar
New User
stock sub is 6" and 100w amp i think, just change the whole thing out, it sucks
Old Jul 3, 2009 | 05:06 PM
chacabaca's Avatar
Icon3 Re: Stock sub in type-s...
that's true, changing everything out would give u the best possible sound. what sucks though, is that the amp that controls the sub also does the mid's and high's in the car. a good system is gonna set u back some, but it's worth it
ahobbs
Audio / Security / Video
Jun 12, 2009 07:55 AM
KING PIN
Jun 24, 2008 07:03 PM
BAR296
Honda Civic (2006 - 2015)
13
Jul 6, 2007 08:21 AM
N4me (06civicsi)
Dec 11, 2006 12:09 PM
hometheaterman
Feb 8, 2005 06:57 AM
