D16y8 header on D16a6
Old Jul 2, 2009 | 02:44 PM
Wilky's Avatar
Default D16y8 header on D16a6
Decided to swap out my stock manifold for a y8 header I had lying around, but I need a bit of info.
Where can I get an O2 sensor wire extension on the cheap? Nowhere local sells them, and I would rather not splice the wiring myself.
If that doesn't work out, has anyone ever spliced and extended their wiring? If so, what gauge wire did you use?
Thanks in advance for the assistance.
Old Jul 2, 2009 | 02:59 PM
Bunger's Avatar
Default Re: D16y8 header on D16a6
I've extended O2 wiring often, and if memory serves, I used 14 gauge wire. I guess if you wanted to make it reversible, go to the junk yard and cut the 2 stock connectors off, splice in enough wire between them to make your extension and plug it in.
Old Jul 2, 2009 | 03:04 PM
EL Vap133's Avatar
I believe I saw them on ebay before.
Old Jul 2, 2009 | 06:08 PM
Wilky's Avatar
I could've swore that I had seen them there before, too. No dice when I searched, though.
Old Jul 2, 2009 | 06:09 PM
Wilky's Avatar
Absolutely great idea. But unfortunately our cars are very rare in junkyards in my neck of the woods. Very few imports for some reason.
Old Jul 2, 2009 | 07:30 PM
jhammond_82's Avatar
Reject Papi
cause you live in tennessee. no inspection right? lol, i've seen cars and trucks with rust holes the size of basket ***** down there. missing fender's and ****. lol.
Old Jul 3, 2009 | 04:43 AM
Wilky's Avatar
Yep. It's cool to not have worries when modding my ride(s), but the drawback is dealing with the hillbillies that leave clouds of smoke for miles behind them with people coughing and flowers wilting as they pass.
Old Jul 3, 2009 | 05:37 AM
D16SiHatch's Avatar
lawlz^
Old Jul 3, 2009 | 06:26 AM
fireant's Avatar
We have these too...There's a rule around here that if you have a full-size black turbo diesel truck, you have to have copious rolling plumes of smoke from two tail pipes or smokestacks. IDK, if my truck did that I would think it was broken and fix it.
I've extended wires for my sensors before... as long as you use the same gauge wire, solder, and heat shrink, it works perfect every time.
Old Jul 3, 2009 | 06:55 AM
Tyson's Avatar
why do you want to extend the O2 sensor wire? the y8 manifold has the O2 close to the front of the engine. and if you have an aftermarket header where the sensor is back near the cat, the stock wire WILL reach over the transmission and plug right in. i did that with my Z6 header. no problem, its just long enough.
Old Jul 3, 2009 | 09:15 AM
Wilky's Avatar
Seriously?
I guess I need to get under the car and try it. Thanks for the info.
Old Jul 3, 2009 | 09:56 AM
Wilky's Avatar
It worked!
I had to remove some of the loom because the O2 sensor plug is loomed together with a few other wires to various whatnots. But it plugs in right around the side of the starter.
Beautiful. Thanks Tyson!
IntegraType-R
Sep 29, 2008 05:40 PM
jdm_eg
Feb 28, 2006 02:01 PM
chethewitt
Mar 17, 2003 05:54 PM
slknv
Jun 18, 2001 09:33 PM
