Need Help With MY EF
Well i have a 91 EF. With the jdm zc.
Recently mY piston rings were Fried..
I just replaced them the other day. And as i was putting it back together i didnt do alighment for the Timing belt... Sadly Bent my values...
Now i just bought a Zc Head, I threw it on. Did alightment for the belt. Put everything back together. It sound diffrent b4 i tried to started it with the bent values. i hear the it trying to start up.
I dont kno wat the problem is. My fire order is right. My spark plugs are good. starters good.
Any Ideas?
Thanks
Any Ideas?
Thanks
again. make sure your cylinder #1 is at TDC and the rotor in the dizzy is aligned with position number 1. try that and get back to me... also make sure you hear the fuel priming when before the initial crank over
jscrib
Sep 16, 2010 08:37 AM
moorevisual
Aug 10, 2009 07:44 AM
