car over heating!!!
If the heater core is leaking you will smell it coming out of the vents if you have the heat on with the air blowing.
Stock radiator and fan setup? If not, check to make sure your fan is blowing in the correct direction. Also when the car is up to temp, check to see if the upper and lower radiator hoses are equally hot. If one is cooler than the other there might be an issue with the water pump.
use a pressure guage to check if there's a leak(radiator, hose, heater core, headgasket.....), if you turbo the car most likely stock radiator not going to work, upgrade the radiator, plus take out the thermostat for better cooling.
