Is this an A/C Blower Motor problem?
Old Jul 2, 2009 | 11:00 AM
dabflyboy's Avatar
Default Is this an A/C Blower Motor problem?
i have a '94 Accord with an a/c problem, so here it goes....
1) A/C air will not blow through the vents no matter which speed the fan is on.
2) air will only come through the vents when i have it on the "outside air" function and i am driving down the highway, so that seems to rule out a blockage..right?
3) also, i can get a very, very, very slight amount of air from the A/C if I tap on the area underneath the glovebox with something like a screwdriver. when i do, there is a slight clicking noise that seems to slow down and fade in conjunction with the amount of air lessening through the vents.
is this a blower problem? is it mechanical (like i need a new blower), or is it electrical (like i need a new relay or something)?
thanks in advance!
Old Jul 2, 2009 | 09:39 PM
dabflyboy's Avatar
Default Re: Is this an A/C Blower Motor problem?
anyone?
Old Jul 3, 2009 | 07:30 AM
91wagon-ex-r's Avatar
New User
One more tip. Go to the junk yard and get 1. make sure you get the whole unit. Blower motor and surrounding plastic it's enclosed in. It's a bitch to re and re just the motor. You may break the plastic housing.
Stew
Old Jul 3, 2009 | 03:08 PM
dabflyboy's Avatar
ITS FIXED!!! went to a U-Pull-It salvage yard and found one. tried it out in the car and the fan spun much faster compared to the old one. a/c works like a champ now. thanks y'all for all of your help!
Old Jul 3, 2009 | 03:18 PM
accord99power's Avatar
yeah i just ssen this post, but if u tap on the motor and it works again or alittle, then that motor is about to take a dump. glad to hear its running again.
lphthephunk
Aug 9, 2014 05:49 AM
kyleclapp
Jan 16, 2008 01:44 AM
vtecsinan
Acura NSX
May 8, 2004 05:11 AM
TekNinja23
Jul 11, 2003 08:26 AM
