engines
go on one of the jdm engine sites, u can get free shipping and usually a 1 year warranty, comes fully assembled minus the tranny, my bro has a b20z in his eg hatch 30,000 miles, no leaks runs like a champ...
A gsr(b18c or b18c1) will run you about 2500 for complete.
A LS you can find at the junkyard, craigslist, HT marketplace for cheap but can't guranteed on the low mileage.
Just take your time and search around if you come up with a deal then your set.
Goodluck.
Goodluck.
b18 (LS) build perfect for a tight budget start stock swap from there vtec head in the future maybe some cams decide turbo or all motor every month set a goal to increase the potential of 1 compotnent maybe one month do head internals or assemble a bottom to increase compression or to lower it aka prepare for boost theres millions of directions off of that base
The OP will have an easy 1k wrapped up in a B series swap if he buys decent mounts, a decent motor, axles, ECU etc.
i agree with changing to multi port its a hell of an upgrade if u ask me, and on a tight budget it is a good idea.....thats what i did, just not running boost cause that could get expensive..
Well it's a rough guess honestly. I wouldn't guess that an a6 manifold, ECU and distributor would cost 200 but it depends on the deals you can find n such also. IT can be done for cheaper/more expensive.
Thanks for your inspirational post on helping him find direction on what he should do
Atleast the other "worthless" posts actually gave him opinions that he was asking for in the first place.
that aint change we can believe in...!!!
