welllll......
Old Jul 2, 2009 | 05:40 AM
8VEYBEYB's Avatar
Default welllll......
So my motor is in my bathroom sitting on the stand , lol and if you wonder why its in my bathroom tis because I had it outside with a trashbag on it and it got wet and I got surface rust in the cylinder wall now anyways I am notching my girdle right now for the eagle rods. When I pulled the motor I pulled the motor out of the tranny and left the tranny in the car , so I had to basically wiggle the damn thing out of the input shaft. next time i will be putting it back in with the tranny attached , that seems much more logical , but in my downtime I'de like to tinker with this tranny and rebuild it. even though its not broken but does have 243k on it (had one rebuild from a very unreliable comapny) and its and Si tranny , Ide like to see what aftermarket is out there for it , Where can I get upgrades for like 300 -400 hp? I want a reliable company. also anyone know of any DIY's anywhere on this? links would be great thanks.
Old Jul 2, 2009 | 05:43 AM
dephtone's Avatar
Default Re: welllll......
Your tranny will hold 3-400 in it's stock form. There are a good amount of people that are running that on a SI trans. If you run stock lifetime axles with it, the axles will break before you trans and the axles are free to replace.
If you want to build the trans with carbon synchros etc etc You may want to PM Mista Bone he is in the transmission section of honda-tech, hes the go to D series trans expert.
Old Jul 2, 2009 | 05:49 AM
8VEYBEYB's Avatar
where can I get a reliable rebuild kit? know of any DIY's? or sites that might help? Ide just like to get carbon synchros and shorter gearing down low and and long gears up high(theoretically that would be great for boost/drag racing right? )
Old Jul 2, 2009 | 06:00 AM
jhammond_82's Avatar
Reject Papi
in the transmission forum, there is a guy who's sn is syncrotech. he'll point you in the right direction for a trans rebuild.
Old Jul 2, 2009 | 06:45 AM
Creator's Avatar
This place has the carbon sync. Could be a good place to call up and ask some questions too....depending on how friendly there guys are.
http://www.gearspeedinc.com/home.htm
civicgen4
Jan 5, 2007 08:06 PM
wreckedmyteg
Jul 18, 2004 06:30 AM
ams0465
Jun 13, 2003 10:07 AM
