crx cable to hydro hasport kit
Old Jul 1, 2009 | 05:17 PM
streetsold6teeny8's Avatar
Default crx cable to hydro hasport kit
so im running a gsr motor with a gsr hydraulic transmission.. I have searched but really no answer as to what im seeking..
i installed it and the clutch pedal is REAL hard.. it is the original crx si cable..idk if the DA is any different.. that white plastic **** on the cable which is used to adjust is all the way to the top and it is all real tight.. i cant turn it down because god knows if itll snap when i drive it... any suggestions. opinions from those who have it please help out anyone thanks...
Old Jul 1, 2009 | 06:06 PM
thiendegigolo's Avatar
Default Re: crx cable to hydro hasport kit
i have the same kit too...im pretty sure it depends on the clutch set up you have...i had it on my ls with b16 hydro tranny with a competition clutch and type r flywheel = it wasnt tight, but gave me enough room to adjust...now that i have a type r tranny with act extreme clutch and pressure plate = **** is tight as a mother! cant adjust at all.....so basically bottom line i personally thing its the clutch set that is to blame
Old Jul 1, 2009 | 06:33 PM
well im running clutch pressure plate and flywheel but it came with the swap so i dont know what kind i think its act... but damn its real hard i guess i have to drive it first... im puttin the car together so i cant drive it yet..
thnks
turbosivtec
12
Apr 26, 2009 11:55 AM
ludesrv
Oct 20, 2008 11:35 AM
DustinM
Mar 25, 2007 11:22 AM
Suzukii
Sep 23, 2005 04:24 PM
