Transmission. Cable.
Old Jul 1, 2009 | 04:08 PM
4NLINE UNLIMITED's Avatar
Icon2 Transmission. Cable.
Is there anyway to tell if you have a B16 YS1 or a LS YS1 w/o cracking out the casing?
This is what the Stamp says on the Transmission. YS1 1035024.
Thanks for Everyone's Help!
Chris.
Old Jul 1, 2009 | 10:00 PM
Default Re: Transmission. Cable.
Anyone?
Old Jul 2, 2009 | 07:36 AM
Originally Posted by 4NLINE UNLIMITED
Anyone?
Echo Echo Echo ...
Old Jul 2, 2009 | 08:07 AM
dephtone's Avatar
Unfortunatly there isn't short of cracking the case open. Other than installing it and seeing how short the gears are... start counting the teeth.
open it up and count the teeth on the fifth gear pair and divide and you'll get the gear ratio for the fifth gear. 0.880 is GSR, 0.742 is LS.
Or you can try this:
just pull the shifter pin all the way out, it's supposed to go in 3rd gear. do the same on the original LS tranny. put your intermediate shaft in, and turn the transmission shaft where the clutch connects, and for one turn of the transmission shaft, count how many turn you get on the intermediate shaft. use white marker to be more exact, and count your ratios this way. the GS-R ys1 should have less intermediate shaft turns per transmission turns than the LS transmission. much more simple than opening it
Old Jul 4, 2009 | 11:05 PM
lunalink's Avatar
sounds way to complicated! lol..
Old Jul 5, 2009 | 05:06 AM
jhammond_82's Avatar
Reject Papi
here ya go! http://www.ff-squad.com/tech/temp/Bgears.htm
alex14
Oct 28, 2011 08:37 AM
Garage 808 Hatch
Transmission & Drivetrain
May 1, 2009 03:10 PM
fatboyslim44
Jan 9, 2006 07:10 PM
