NEED HELP FAST...I keep on blowing the ecu eat ecu fuse
Old Aug 21, 2002 | 08:10 PM
qwklude82's Avatar
Default NEED HELP FAST...I keep on blowing the ecu eat ecu fuse
Well after getting everything dyno'ed and making my 250.3 whp today i noticed my speedometer wasn't working. Then i noticed my a/f gauge wasn't working. So i looked at the fuses under the dash and noticed that the ecu fuse was blown. I tried 5 different ways to fix it and blew all 5 fuses. I can't figure out what i did wrong. I installed the vafc a couple days ago, however with all this happening I haven't got a CEL. Although I have had the battery and brake light come on faintly. I'm assuming these are coming on b/c of the blown ecu fuse. Not too sure though...PLS help!!
Justin
Old Aug 21, 2002 | 11:44 PM
quickspoolin's Avatar
Default Re: NEED HELP FAST...I keep on blowing the ecu eat ecu fuse (qwklude82)
Not an expert but you should check all ground wires that you've been messin with and power wires. Maybe one of your power wires is rubbing on the frame.
Old Aug 21, 2002 | 11:47 PM
Kamin's Avatar
Default Re: NEED HELP FAST...I keep on blowing the ecu eat ecu fuse (quickspoolin)
sounds like an open wire/crossed wires.
jmpassey
May 31, 2018 06:46 PM
italstallion
Mar 24, 2008 08:13 AM
j-specB20sol
10
Oct 23, 2007 04:37 PM
onepoint-gsr
Feb 28, 2006 01:55 AM
AzntaggeR
Feb 19, 2006 06:54 PM
