(90 Integra) CEL code 15 - Ignition Output Signal
I got this error code while driving to work. Engine cut off, would not start back up. CEL light, battery light, and Oil light came on. I was able to crank motor with a healthly sounding starter but...could not get engine to turn and stay on.
I brought the car back home in the morning (Thanks AAA)...later in the day I went to the garage to check the code and saw 15 - Ignition Output Signal....what the hell does that mean?
AND now here's the kicker, I cranked the car and it started up just fine. I left the car running for about 20min. turned everything on...A/C, lights put it in gear and back, and let it rev. to 3k for about a few min....nothing.
I don't trust this though. I need to figure out what the hell exactly happened.
My mechanic friend said last night after I told him what lights on the dash came on, and he immediately said....Alternator. But why is it that the car now just starts fine and runs??
i just got this code
my car broke down on the freeway. i got it home and took off the dizzy cap and found the rotor came loose and my coil was shot. so i bought a new coil. tryed starting it and wouldnt start and the cel 15 came on
You can check the yellow/black wire for voltage.. (I believe it's yellow/black, but it's been a while) I put some information about this in the faq thread..
https://honda-tech.com/forums/acura-integra-6/1994-2001-gen-3-all-general-information-specifications-2306055/
