Anyone with a vtec controller help out...
Well I got some questions. First off I bought a Fields VTEC controller, boxer series. Anyway I bought it used off a guy for 100 bucks. PRetty much brand new he told me he used it for 3 weeks, he had a greddy emanage thing in his civic.
Anyway he was telling me that the only way I can run the VTEC controller was if I had a VTEC computer, but I dont think thats right. I think you can run a vtec controller with any computer, as long as your cars VTEC. So my question is can you? I just want to clarify this. I am running non obd with an 89 integra computer.
Also, if I can hook it up, what wires do I have to hook up for the fuel and for the vtec activation and ****, or does someone have a manuel for a non obd 88-91 crx/civic? I am just wondering, I am gonna install it Friday so I just want to have all the information I can have before then. Thanks.
im runin a apexi vafc right now and im obdo with a z6 motor, just wire the vtec wire from the harness straight to the solenoid, and for the others just find instruction manual, the apex instructions come with ones that show it for a ef8 so its basically same wiring as ours just has the extra wires for the b16
what motor are you running? sohc vtec? how is your vtec actuated now, rpm activator? If so vtec controller won't change your vtec engagement point, a new pill will. Get a vtec ecu man! where is Duncanville? maybe I can help you out.
I am actually running a switch from like Autozone on it now, just a striaght switch. I was just running that for like 2 weeks till I got a vtec controller. I am in Duncanville like right off of hgihway 67...
ED9 so your not running a RPM activated switch or anything? You just have your VTEC actuated by the VTEC controller right? It does everything for you, alll you do is decide when it comes on, and when it dont pretty much, and play with fuel curves.
lol, basically as in what? Like are you running something else, or just hte VTEC controller. I am like 99% sure you dont need anything else to run it. I am just trying to be sure. I dont want to not have everything when i hook it up.
What wires do the SFC hook up too? Since we have none electrical speedometers is there a way i can hook my speedo wire up?
just runing the vafc nothing else.... try and find the wiring diagram for the fields, 1 of the wires going ot the ecu is the rpm signal wich will read out the rpm.
I have all the wiring for VTEC hooked up, just nothing for the fuel curves. I think it goes tot he map sensor or something lek that.
i found this on some website, Fields Boxer SFC VTEC controller
for PM6 (88-91 civic/crx) or PG7 (88-89 1.6L integra) ecu application only
SFC VTEC controller ECU PIN location
Red wire splice/connect to A15 (yellow/black)
Green wire splice/connect to B15 (white1)
Dark blue wire to VTEC solenoid (green/yellow)
Yellow wire not used on PM6 ecu
White/green wire not used on PM6 ecu
Purple wire cut/connect to B16 ECU side harness
Si/Hf = white/red , DX = yellow/red
Light blue wire cut/connect to B16 Engine side harness
Orange wire cut/connect to C11 ECU side harness
Si/Hf = white1 , DX = orange
Brown wire cut/connect to C11 ENGINE side harness
Black wire (-) Ground
[Modified by ED9Hybrid, 4:43 PM 8/22/2002]
There speedometer wires or something like that. So I dont relaly care about that one. Gonan go hook up the last wire.
Okay now I got one more problem....
I had to replace the ignitor in my distributor before.. And when I repalced it, after I put it in, my controllers RPM is different then the RPM on the tach? The tach rpm is right. As the TACH RPM rises the controllers ones get farther apart. I dont know if something is messed up on the controller or what. Can someone hit me up with an idea of what it could be? I have the controller set to give me VTEC at 3200 and it kicks in at 5200, if I want it at 5500 then i have to set it at 3500, its weird. I just need some suggestions, to why my Sunrpo tach and my VTEC controller are getting two different RPM readings, I have them both hooked to the same coil wire..
i Okay now I got one more problem....
i have the same problem with my pivot tach........still trying to figure that 1 out
I dont know whether the fields controller is the same, but on the vafc you have to make sure its set for a 4 cylinder, otherwise the revs will be way off.......dont exactly know how it works, but when i first connected my VAFc I had this prob, til i went back in an read the instructions
when u adjust the back, make sure the rpm on ur cluster n the controller matches. when i first got mine, the damn shop didnt adjust so i was lossing hp. u need to make sure its the same, now mine is perfect.
Okay and seriously, this is my last set of questions, unless I have a question about an answer.
How do I set fuel curves? Everytime I take off it says "OF". I dont know how to set them and if it even makes a difference that I will notice. Anyone have some presets I could use for hte fields controller?
