speed senson..need help???
Old Jun 30, 2009 | 06:14 PM
jspec08's Avatar
New User
Default speed senson..need help???
on ef's the speed sensor is run through a cable, not a harness plug like eg, ek, ect... this being so how does the ecu pick up speed sensor code ???? plz help
Old Jun 30, 2009 | 06:17 PM
jspec08's Avatar
New User
Default Re: speed senson..need help???
plz help me out..me and a few people were wondering this about our efs
Old Jun 30, 2009 | 06:32 PM
mayfly's Avatar
the ecu is not related with it, because its cable it therefore is manually operated, the ecu knows how to give the right amount of fuel and air intake by the engine. this has nothing to do with speed, therefore you can go 20 mph and be at 4k rpm in first gear or 70mph in 4th at 4k and still be using the same amount of fuel/air etc etc. make sense? the speed you travel has nothing to do with that mixture, if this didn't hlp hit me up on aim and i will try to futher help
Old Jun 30, 2009 | 08:22 PM
D16SiHatch's Avatar
there is a unit inside the gauge cluster that converts the mechanical turning of the cable into an electronic output, which is then passed on to the ecu.
Old Jul 1, 2009 | 04:50 PM
raffaelli's Avatar
my speedo is disconnected due to the location of the horizontal roll cage bar in the dash. Once in a while I get a speed sensor error. Somehow the speedo cable feeds information to the ECU.
Old Jul 1, 2009 | 05:59 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Look at the last post I made here for pics:
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/crx-how-change-tranny-fluid-1325930/
Old Jul 1, 2009 | 07:44 PM
jspec08's Avatar
New User
thnx guyys
hypeRhatch
Sep 15, 2013 10:33 AM
LAWST
Mar 3, 2005 06:51 PM
dirtracer
Feb 9, 2005 06:36 AM
vteclimey
Oct 13, 2001 11:55 PM
