89dx with 90si wiring
i have a 89 crx dx and i put a B16 obd0 motor in it. my ? is i got a 90 crx si wiring harness from under the dash will in plug right in or will i have to chang something
the dash harness will plug directly to the b16 motor harness(if i t came with it) because they're 4 pnt injectors...last week i had to change my stock dx dash harness to a crx si and i conected it to the ls motor harness...it was a pain cuz i had to change all the wiring
yeah me to i have the harness but when i was pluging it all in under the dash there are 2 plugs that will not plug to anything under driver side dash did this happen to you to
do u have the full dash harness? it comes with all the wires to the headlights,conrers,,etc,and also i changed it cuz i put an si dash board and cluster and the dx dash harness doesnt come with the cable to the rpm...well at least i dont know how to wire it personally...
Why bother with all the headaches? Just use your existing wiring harness and add the necessary wires for MPFI and VTEC. Ripping apart your interior just to use another harness is not worth IMO.
honda_crxzc
Jan 16, 2011 08:51 PM
RA122324
Jun 28, 2005 03:06 AM
jedubz
Sep 23, 2004 08:14 AM
MaxED9
15
Mar 18, 2004 09:02 AM
