I need help with Mahle Pistons(H22A).
Old Jun 30, 2009 | 04:51 PM
nus_dogg's Avatar
Default I need help with Mahle Pistons(H22A).
Ok, I found what I was looking at:
The GoldSeries H22 Piston Kit includes:
- 22mm High quality steel wrist pins
- Round wire locks
- Available in: Flat Top, High Comp Dome, or in supercharger, turbo, or nitrous ready Inverted Dome.
- Precision ring grooves for 1.2, 1.2, 2.8mm rings included.
My car is going to be a weekend DD. Do I want Flat Top, High Comp Dome?? I have no clue as to what these are suppose to do. Some advice and tips are appreciated.
Also,
I found the spec I wanted for my High CR pistons.
My Concern:
The piston vol. off the Mahle pistons=10cc
The piston vol. off the stock pistons(JDM H22A)=1.9cc
So I wonder if they ever fixed the issue about the valve relief that they were having a few years ago?? Thats why I brought up those concerns of mine since the numbers are sort of different.
Old Jun 30, 2009 | 04:58 PM
nus_dogg's Avatar
Default Re: I need help with Mahle Pistons(H22A).
Here's the rest of the Piston info:
Mahle Pistons(Gold Series):
Bore=87.00mm
Stroke=90.00mm
Rod Length=143mm
Pin Diameter=22mm
Comp Height=31mm
Dome Volume=10cc
Weigh Gram=342g
CR(What I wanted)=11.5
Stock JDM H22A pistons:
Bore=87.00mm
Stroke=90.00mm
Rod Length=143mm
wrist pin=22.0mm
Comp Height=31mm
Dome Volume=1.9cc
Weigh Gram=unlisted
CR=10.6
Old Jul 1, 2009 | 07:48 AM
accord99power's Avatar
needs to go in the engine section of this forum, and you want to include what your plans are turbo, nitrous, supercharge, or just all motor.
Hector Valencia
Apr 11, 2015 01:52 PM
91-lsvtecsi
Mar 25, 2014 09:54 AM
thegatekeeper14
Jan 18, 2011 04:18 PM
93H22ACX
Apr 23, 2004 06:07 PM
