1990 accord motor swap
Old Jun 30, 2009 | 01:31 PM
justin3po's Avatar
Default 1990 accord motor swap
i have 1990 accord i broke my timing belt and im swapping the motor with the same exact motor but my car is a 5spd and the motor came out of an automatic is there anything im going to need for the transmission to line up??
Old Jun 30, 2009 | 01:41 PM
nus_dogg's Avatar
Default Re: 1990 accord motor swap
No. The engine that came auto will bolt right up to your 5spd tranny with no modification. Just transferr flywheel, 5spd flywheel bolt, T/O, & clutch over to your new engine. While you're at it, I recommend you replacing your rear main seal. They tend to leak over time. So do it while you're there.
Old Jun 30, 2009 | 01:58 PM
justin3po's Avatar
alright sweet thanks yea my rear main seal was leaking and were putting a whole new clutch in because my car had idle problems and my dad thinks it took a tole on my clutch i currently had but thanks for the info!
youngturbo
Honda Civic (2001 - 2005)
Jun 8, 2010 01:09 PM
hksdrager
Mar 28, 2007 08:50 AM
russianswty
Feb 14, 2007 03:24 PM
Prelude909
Sep 29, 2004 10:46 AM
