Help With Camber Kits
I want to get a camber kit for my 91 civic std, but i dont know which type to get. I was looking at the ingalls ball joint camber kit, but its not full adjustable, but the skunk2 upper control arm camber kit is. But i think the ingalls camber kit will be enough to adjust my camber. Anyways which one would be best for me. The alignment guy said i have 2.5 degree camber. Which is easier to install, i sometimes have problems doing stuff to the hubs something is always happens like my balljoint stud starts to move when i try to loosen it. So i want something that would do the job and be the easy way out. Thanks
tell the alignment guy to do the alignment anyway. camber doesn't kill tires toe does save your money on a camber kit and use it on something more useful. just tell him to make sure the toe is zero'd out or within factory specs and you'll be fine
you sure my camber is pretty bad. He said my tires will still get camber ware on the tires. Here is a pic. I know my toe is off but also look at the camber.
hard to tell anything from that perspective. looks like you have horrible offset wheels tho, but again, it might be the perspective.
show a side shot to see how low you are, and a higher front end shot.
but most likely, your camber is fine. it doesnt affect tire wear much. its the toe that chews up tires, ppl only notice the camber tho.
get an alignment.
get an alignment.
itsJDMyo
13
Jan 7, 2005 10:40 AM
