problem putting on rear coilovers
Old Aug 21, 2002 | 07:01 PM
GsR HtCh's Avatar
Default problem putting on rear coilovers
just wondering if anyone knows what to do here. i was trying to put coilovers on the rear of my 98 hatch and i stripped the hex part at the top or the shock. the part that you have to take the panels out to get to. just wondering if there is another way to get that nut off. will a torque gun work?? any suggestions.
Old Aug 21, 2002 | 08:08 PM
DelSol808's Avatar
Default Re: problem putting on rear coilovers (98civichtchback)
uhh if you are replacing the strut (its kinda stupid to use the stripped one) just use some vice grips on the bottom part ( the skinny silver shaft ) under the rubber thing (i forget what its called)......
Old Aug 22, 2002 | 04:30 AM
GsR HtCh's Avatar
Default Re: problem putting on rear coilovers (DelSol808)
anyone else
Old Aug 22, 2002 | 06:00 AM
MyWhiteCivic's Avatar
I did the same damn thing. The bolt was siezed on there. I bought an air wrench though so I will see if that works.
I'm not sure if you want to stick anything inside that spring when you take off the top nut. It just doesn't seem like a good idea to me.
Old Aug 22, 2002 | 06:27 AM
Jaminak's Avatar
Default Re: problem putting on rear coilovers (MyWhiteCivic)
If you are using a spring compressor your shouldn't have any problems with that. It's probably what I would do. But after using vise grips on that shart you <U>will</U> need to get new shocks.
MUGEN_EG95
Nov 13, 2008 11:58 AM
fms1day
Jun 23, 2005 02:50 PM
KaMeKaZi
Oct 15, 2004 10:50 AM
Attoir
Feb 19, 2004 05:24 PM
pr0jektdc2
Feb 15, 2004 01:56 PM
